RTEMS Logo
RTEMS 4.6.1 On-Line Library
Initialization Code boot_card() - Boot the Card
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
7.3.2: boot_card() - Boot the Card
The boot_card() is the first C code invoked. Most of the BSPs use the same shared version of boot_card() which is located in the following file:
c/src/lib/libbsp/shared/main.c
The boot_card() routine performs the following functions:
It is important to note that the executive and much of the support environment must be initialized before invoking main().
