RTEMS Logo
RTEMS 4.6.1 On-Line Library
Dual-Ported Memory Manager PORT_CREATE - Create a port
15.4.1: PORT_CREATE - Create a port
CALLING SEQUENCE:
procedure Port_Create (
   Name           : in     RTEMS.Name;
   Internal_Start : in     RTEMS.Address;
   External_Start : in     RTEMS.Address;
   Length         : in     RTEMS.Unsigned32;
   ID             :    out RTEMS.ID;
   Result         :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - port created successfully
RTEMS.INVALID_NAME - invalid task name
RTEMS.INVALID_ADDRESS - address not on four byte boundary
RTEMS.TOO_MANY - too many DP memory areas created
DESCRIPTION:
This directive creates a port which resides on the local node for the specified DPMA. The assigned port id is returned in id. This port id is used as an argument to other dual-ported memory manager directives to convert addresses within this DPMA.
For control and maintenance of the port, RTEMS allocates and initializes an DPCB from the DPCB free pool. Thus memory from the dual-ported memory area is not used to store the DPCB.
NOTES:
The internal_address and external_address parameters must be on a four byte boundary.
This directive will not cause the calling task to be preempted.
