The rtems.port_create
directive creates a port into a DPMA
with the user-defined name. The user specifies the association
between internal and external representations for the port being
created. RTEMS allocates a Dual-Ported Memory Control Block
(DPCB) from the DPCB free list to maintain the newly created
DPMA. RTEMS also generates a unique dual-ported memory port ID
which is returned to the calling task. RTEMS does not
initialize the dual-ported memory area or access any memory
within it.
