RTEMS Logo
RTEMS 4.6.1 On-Line Library
Region Manager REGION_GET_SEGMENT_SIZE - Obtain size of a segment
14.4.7: REGION_GET_SEGMENT_SIZE - Obtain size of a segment
CALLING SEQUENCE:
procedure Region_Get_Segment_Size (
   ID         : in     RTEMS.ID;
   Segment    : in     RTEMS.Address;
   Size       :    out RTEMS.Unsigned32;
   Result     :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - segment obtained successfully
RTEMS.INVALID_ID - invalid region id
RTEMS.INVALID_ADDRESS - segment address not in region
DESCRIPTION:
This directive obtains the size in bytes of the specified segment.
NOTES:
The actual length of the allocated segment may be larger than the requested size because a segment size is always a multiple of the region's page size.
