procedure Message_Queue_Ident ( Name : in RTEMS.Name; Node : in RTEMS.Unsigned32; ID : out RTEMS.ID; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL
- queue identified successfully
RTEMS.INVALID_NAME
- queue name not found
RTEMS.INVALID_NODE
- invalid node id
This directive obtains the queue id associated with the queue name specified in name. If the queue name is not unique, then the queue id will match one of the queues with that name. However, this queue id is not guaranteed to correspond to the desired queue. The queue id is used with other message related directives to access the message queue.
This directive will not cause the running task to be preempted.
If node is RTEMS.SEARCH_ALL_NODES
, all nodes are searched
with the local node being searched first. All other nodes are
searched with the lowest numbered node searched first.
If node is a valid node number which does not represent the local node, then only the message queues exported by the designated node are searched.
This directive does not generate activity on remote nodes. It accesses only the local copy of the global object table.
