RTEMS Logo
RTEMS 4.6.1 On-Line Library
Timer Manager TIMER_IDENT - Get ID of a timer
8.4.2: TIMER_IDENT - Get ID of a timer
CALLING SEQUENCE:
procedure Timer_Ident (
   Name   : in     RTEMS.Name;
   ID     :    out RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - timer identified successfully
RTEMS.INVALID_NAME - timer name not found
DESCRIPTION:
This directive obtains the timer id associated with the timer name to be acquired. If the timer name is not unique, then the timer id will match one of the timers with that name. However, this timer id is not guaranteed to correspond to the desired timer. The timer id is used to access this timer in other timer related directives.
NOTES:
This directive will not cause the running task to be preempted.
