RTEMS Logo
RTEMS 4.6.1 On-Line Library
Task Manager TASK_WAKE_WHEN - Wake up when specified
5.4.14: TASK_WAKE_WHEN - Wake up when specified
CALLING SEQUENCE:
procedure Task_Wake_When (
   Time_Buffer : in     RTEMS.Time_Of_Day;
   Result      :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - awakened at date/time successfully
RTEMS.INVALID_TIME_OF_DAY - invalid time buffer
RTEMS.NOT_DEFINED - system date and time is not set
DESCRIPTION:
This directive blocks a task until the date and time specified in time_buffer. At the requested date and time, the calling task will be unblocked and made ready to execute.
NOTES:
The ticks portion of time_buffer record is ignored. The timing granularity of this directive is a second.
A clock tick is required to support the functionality of this directive.
