Starting FTPD is done with a call to rtems_initialize_ftpd()
The configuration structure must be provided in the application
source code. Example hooks structure and configuration structure
folllow.
struct rtems_ftpd_hook ftp_hooks[] = { {"untar", Untar_FromMemory}, {NULL, NULL} }; struct rtems_ftpd_configuration rtems_ftpd_configuration = { 40, /* FTPD task priority */ 512*1024, /* Maximum hook 'file' size */ 0, /* Use default port */ ftp_hooks /* Local ftp hooks */ };
Specifying 0 for the well-known port causes FTPD to use the UNIX standard FTPD port (21).
Copyright © 1988-2003 OAR Corporation
