The function provided in this section is functionally equivalent to
the command route add default gw yyy.yyy.yyy.yyy
void mon_ifconfig(int argc, char *argv[], unsigned32 command_arg, boolean verbose) { struct sockaddr_in ipaddr; struct sockaddr_in dstaddr; struct sockaddr_in netmask; struct sockaddr_in broadcast; char *iface; int f_ip = 0; int f_ptp = 0; int f_netmask = 0; int f_up = 0; int f_down = 0; int f_bcast = 0; int cur_idx; int rc; int flags; bzero((void*) &ipaddr, sizeof(ipaddr)); bzero((void*) &dstaddr, sizeof(dstaddr)); bzero((void*) &netmask, sizeof(netmask)); bzero((void*) &broadcast, sizeof(broadcast)); ipaddr.sin_len = sizeof(ipaddr); ipaddr.sin_family = AF_INET; dstaddr.sin_len = sizeof(dstaddr); dstaddr.sin_family = AF_INET; netmask.sin_len = sizeof(netmask); netmask.sin_family = AF_INET; broadcast.sin_len = sizeof(broadcast); broadcast.sin_family = AF_INET; cur_idx = 0; if (argc <= 1) { /* display all interfaces */ iface = NULL; cur_idx += 1; } else { iface = argv[1]; if (isdigit(*argv[2])) { if (inet_pton(AF_INET, argv[2], &ipaddr.sin_addr) < 0) { printf("bad ip address: %s\n", argv[2]); return; } f_ip = 1; cur_idx += 3; } else { cur_idx += 2; } } if ((f_down !=0) && (f_ip != 0)) { f_up = 1; } while(argc > cur_idx) { if (strcmp(argv[cur_idx], "up") == 0) { f_up = 1; if (f_down != 0) { printf("Can't make interface up and down\n"); } } else if(strcmp(argv[cur_idx], "down") == 0) { f_down = 1; if (f_up != 0) { printf("Can't make interface up and down\n"); } } else if(strcmp(argv[cur_idx], "netmask") == 0) { if ((cur_idx + 1) >= argc) { printf("No netmask address\n"); return; } if (inet_pton(AF_INET, argv[cur_idx+1], &netmask.sin_addr) < 0) { printf("bad netmask: %s\n", argv[cur_idx]); return; } f_netmask = 1; cur_idx += 1; } else if(strcmp(argv[cur_idx], "broadcast") == 0) { if ((cur_idx + 1) >= argc) { printf("No broadcast address\n"); return; } if (inet_pton(AF_INET, argv[cur_idx+1], &broadcast.sin_addr) < 0) { printf("bad broadcast: %s\n", argv[cur_idx]); return; } f_bcast = 1; cur_idx += 1; } else if(strcmp(argv[cur_idx], "pointopoint") == 0) { if ((cur_idx + 1) >= argc) { printf("No pointopoint address\n"); return; } if (inet_pton(AF_INET, argv[cur_idx+1], &dstaddr.sin_addr) < 0) { printf("bad pointopoint: %s\n", argv[cur_idx]); return; } f_ptp = 1; cur_idx += 1; } else { printf("Bad parameter: %s\n", argv[cur_idx]); return; } cur_idx += 1; } printf("ifconfig "); if (iface != NULL) { printf("%s ", iface); if (f_ip != 0) { char str[256]; inet_ntop(AF_INET, &ipaddr.sin_addr, str, 256); printf("%s ", str); } if (f_netmask != 0) { char str[256]; inet_ntop(AF_INET, &netmask.sin_addr, str, 256); printf("netmask %s ", str); } if (f_bcast != 0) { char str[256]; inet_ntop(AF_INET, &broadcast.sin_addr, str, 256); printf("broadcast %s ", str); } if (f_ptp != 0) { char str[256]; inet_ntop(AF_INET, &dstaddr.sin_addr, str, 256); printf("pointopoint %s ", str); } if (f_up != 0) { printf("up\n"); } else if (f_down != 0) { printf("down\n"); } else { printf("\n"); } } if ((iface == NULL) || ((f_ip == 0) && (f_down == 0) && (f_up == 0))) { rtems_bsdnet_show_if_stats(); return; } flags = 0; if (f_netmask) { rc = rtems_bsdnet_ifconfig(iface, SIOCSIFNETMASK, &netmask); if (rc < 0) { printf("Could not set netmask: %s\n", strerror(errno)); return; } } if (f_bcast) { rc = rtems_bsdnet_ifconfig(iface, SIOCSIFBRDADDR, &broadcast); if (rc < 0) { printf("Could not set broadcast: %s\n", strerror(errno)); return; } } if (f_ptp) { rc = rtems_bsdnet_ifconfig(iface, SIOCSIFDSTADDR, &dstaddr); if (rc < 0) { printf("Could not set destination address: %s\n", strerror(errno)); return; } flags |= IFF_POINTOPOINT; } /* This must come _after_ setting the netmask, broadcast addresses */ if (f_ip) { rc = rtems_bsdnet_ifconfig(iface, SIOCSIFADDR, &ipaddr); if (rc < 0) { printf("Could not set IP address: %s\n", strerror(errno)); return; } } if (f_up != 0) { flags |= IFF_UP; } if (f_down != 0) { printf("Warning: taking interfaces down is not supported\n"); } rc = rtems_bsdnet_ifconfig(iface, SIOCSIFFLAGS, &flags); if (rc < 0) { printf("Could not set interface flags: %s\n", strerror(errno)); return; } } void mon_route(int argc, char *argv[], unsigned32 command_arg, boolean verbose) { int cmd; struct sockaddr_in dst; struct sockaddr_in gw; struct sockaddr_in netmask; int f_host; int f_gw = 0; int cur_idx; int flags; int rc; memset(&dst, 0, sizeof(dst)); memset(&gw, 0, sizeof(gw)); memset(&netmask, 0, sizeof(netmask)); dst.sin_len = sizeof(dst); dst.sin_family = AF_INET; dst.sin_addr.s_addr = inet_addr("0.0.0.0"); gw.sin_len = sizeof(gw); gw.sin_family = AF_INET; gw.sin_addr.s_addr = inet_addr("0.0.0.0"); netmask.sin_len = sizeof(netmask); netmask.sin_family = AF_INET; netmask.sin_addr.s_addr = inet_addr("255.255.255.0"); if (argc < 2) { rtems_bsdnet_show_inet_routes(); return; } if (strcmp(argv[1], "add") == 0) { cmd = RTM_ADD; } else if (strcmp(argv[1], "del") == 0) { cmd = RTM_DELETE; } else { printf("invalid command: %s\n", argv[1]); printf("\tit should be 'add' or 'del'\n"); return; } if (argc < 3) { printf("not enough arguments\n"); return; } if (strcmp(argv[2], "-host") == 0) { f_host = 1; } else if (strcmp(argv[2], "-net") == 0) { f_host = 0; } else { printf("Invalid type: %s\n", argv[1]); printf("\tit should be '-host' or '-net'\n"); return; } if (argc < 4) { printf("not enough arguments\n"); return; } inet_pton(AF_INET, argv[3], &dst.sin_addr); cur_idx = 4; while(cur_idx < argc) { if (strcmp(argv[cur_idx], "gw") == 0) { if ((cur_idx +1) >= argc) { printf("no gateway address\n"); return; } f_gw = 1; inet_pton(AF_INET, argv[cur_idx + 1], &gw.sin_addr); cur_idx += 1; } else if(strcmp(argv[cur_idx], "netmask") == 0) { if ((cur_idx +1) >= argc) { printf("no netmask address\n"); return; } f_gw = 1; inet_pton(AF_INET, argv[cur_idx + 1], &netmask.sin_addr); cur_idx += 1; } else { printf("Unknown argument\n"); return; } cur_idx += 1; } flags = RTF_STATIC; if (f_gw != 0) { flags |= RTF_GATEWAY; } if (f_host != 0) { flags |= RTF_HOST; } rc = rtems_bsdnet_rtrequest(cmd, &dst, &gw, &netmask, flags, NULL); if (rc < 0) { printf("Error adding route\n"); } }
Thanks to Jay Monkman for this example code.
Copyright © 1988-2003 OAR Corporation
