RTEMS Logo
RTEMS 4.6.0pre5 On-Line Library
System Configuration
PREV UP NEXT Bookshelf RTEMS Network Supplement
3.2: System Configuration
The networking tasks allocate some RTEMS objects. These must be accounted for in the application configuration table. The following lists the requirements.
TASKS
One network task plus a receive and transmit task for each device.
SEMAPHORES
One network semaphore plus one syslog mutex semaphore if the application uses openlog/syslog.
EVENTS
The network stack uses RTEMS_EVENT_24 and RTEMS_EVENT_25. This has no effect on the application configuration, but application tasks which call the network functions should not use these events for other purposes.
Copyright © 1988-2003 OAR Corporation
