RTEMS Logo
RTEMS 4.6.0 On-Line Library
Conclusion
PREV UP next Bookshelf RTEMS Remote Debugger Server Specifications
Chapter 8: Conclusion
In this document we have presented how we envisage to add remote debugging facilities to RTEMS by implementing a remote debugger daemon for GDB. As any debug implemented in software, it will have limitation but we are confident that most of them can be removed by adding separate software components dedicated to debug activity. We must keep in mind that even with this approach, no software will enable the debug of code with interrupt entirely masked at processor level and that In Circuit Emulator (ICE) or use of BDM extension on the target board are the ultimate way to really debug any portion of an RTOS. BDM support in GDB is still weak but people are working on it and we may get something better in a near future.
remote debugger tasks and handlers
