RTEMS Logo
RTEMS 4.6.0 On-Line Library
List of Requirements
PREV UP NEXT Bookshelf RTEMS Remote Debugger Server Specifications
3.1: List of Requirements
We will identify here possible requirements for the type of debug that may be provided :
[(R1)]:
We want to use GDB as the front-end debugger,
[(R2)]:
We want to support at least Intel and PowerPC as target processor architecture,
[(R3)]:
We want to use the GDB thread debugging interface,
[(R4)]:
We want to be able to debug a remote target over a serial line,
[(R5)]:
We want to be able to debug a remote target over Ethernet,
[(R6)]:
The set of target code path we will be able to debug using RGDBSD must be clearly identified. It will be called Debug Path Set (DPS) in the remaining of this document,
[(R7)]:
DPS must include the RTEMS core executive itself,
[(R8)]:
DPS must include the FreeBSD stack,
[(R9)]:
DPS must include anything but the FreeBSD stack and the RTEMS core executive,
[(R10)]:
We want to enable several persons to debug different parts of the code running on the target,
[(R11)]:
As much as possible the system must be frozen during a debug session so that debugging a particular portion of code does not prevent another part from functioning,
