RTEMS Logo
RTEMS 4.6.0 On-Line Library
Example Application
PREV UP NEXT Bookshelf RTEMS C User's Guide
Chapter 25: Example Application
 *  This file contains an example of a simple RTEMS
 *  application.  It instantiates the RTEMS Configuration
 *  Information using confdef.h and contains two tasks:
 *  a *  user initialization task and a simple task.
 *  This example assumes that a board support package exists.
rtems_task user_application(rtems_task_argument argument);
rtems_task init_task(
  rtems_task_argument ignored
  rtems_id          tid;
  rtems_status_code status;
  rtems_name        name;
  name = rtems_build_name( 'A', 'P', 'P', '1' )
  status = rtems_task_create(
     name, 1, RTEMS_MINIMUM_STACK_SIZE,
     RTEMS_NO_PREEMPT, RTEMS_FLOATING_POINT, &tid
  if ( status != RTEMS_STATUS_SUCCESSFUL ) {
    printf( "rtems_task_create failed with status of %d.\n", status );
    exit( 1 );
  status = rtems_task_start( tid, user_application, 0 );
    printf( "rtems_task_start failed with status of %d.\n", status );
    exit( 1 );
  status = rtems_task_delete( SELF );    /* should not return */
  printf( "rtems_task_delete returned with status of %d.\n", status );
  exit( 1 );
  /* application specific initialization goes here */
  while ( 1 )  {              /* infinite loop */
    /*  APPLICATION CODE GOES HERE
     *  This code will typically include at least one
     *  directive which causes the calling task to
     *  give up the processor.
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER  /* for stdio */
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER    /* for time services */
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'E', 'X', 'A', 'M' )
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <confdefs.h>
