BSP and Device Driver Development Guide
The Read_timer
routine
returns the number of benchmark time units (typically microseconds)
that have elapsed since the last call to Timer_initialize
int Read_timer(void) { stop time = read the hardware timer if the subtract overhead feature is enabled subtract overhead from stop time return the stop time }
Many implementations of this routine subtract the overhead required to initialize and read the benchmark timer. This makes the times reported more accurate.
Some implementations report 0 if the harware timer value change is sufficiently small. This is intended to indicate that the execution time is below the resolution of the timer.
