RTEMS Logo
RTEMS 4.6.0 On-Line Library
Configuring a System CPU Dependent Information Table
22.6: CPU Dependent Information Table
The CPU Dependent Information Table is used to describe processor dependent information required by RTEMS. This table is generally used to supply RTEMS with information only known by the Board Support Package. The contents of this table are discussed in the CPU Dependent Information Table chapter of the Applications Supplement document for a specific target processor.
The confdefs.h mechanism does not support generating this table. It is normally filled in by the Board Support Package.
