RTEMS Logo
RTEMS 4.6.0 On-Line Library
I/O Manager IO_REGISTER_DRIVER - Register a device driver
16.4.1: IO_REGISTER_DRIVER - Register a device driver
CALLING SEQUENCE:
No Ada implementation.
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully registered
RTEMS.INVALID_NUMBER - invalid major device number
RTEMS.TOO_MANY - no available major device table slot
RTEMS.RESOURCE_IN_USE - major device number entry in use
DESCRIPTION:
This directive attempts to add a new device driver to the Device Driver Table. The user can specify a specific major device number via the directive's major parameter, or let the registration routine find the next available major device number by specifing a major number of 0. The selected major device number is returned via the registered_major directive parameter. The directive automatically allocation major device numbers from the highest value down.
This directive automatically invokes the IO_INITIALIZE directive if the driver address table has an initialization and open entry.
The directive returns RTEMS.TOO_MANY if Device Driver Table is full, and RTEMS.RESOURCE_IN_USE if a specific major device number is requested and it is already in use.
NOTES:
The Device Driver Table size is specified in the Configuration Table condiguration. This needs to be set to maximum size the application requires.
