procedure Region_Get_Segment ( ID : in RTEMS.ID; Size : in RTEMS.Unsigned32; Option_Set : in RTEMS.Option; Timeout : in RTEMS.Interval; Segment : out RTEMS.Address; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - segment obtained successfully
RTEMS.INVALID_ID - invalid region id
RTEMS.INVALID_SIZE - request is for zero bytes or exceeds
the size of maximum segment which is possible for this region
RTEMS.UNSATISFIED - segment of requested size not available
RTEMS.TIMEOUT - timed out waiting for segment
RTEMS.OBJECT_WAS_DELETED - semaphore deleted while waiting
This directive obtains a variable size segment from
the region specified by id. The address of the allocated
segment is returned in segment. The RTEMS.WAIT
and RTEMS.NO_WAIT components
of the options parameter are used to specify whether the calling
tasks wish to wait for a segment to become available or return
immediately if no segment is available. For either option, if a
sufficiently sized segment is available, then the segment is
successfully acquired by returning immediately with the
RTEMS.SUCCESSFUL status code.
If the calling task chooses to return immediately and
a segment large enough is not available, then an error code
indicating this fact is returned. If the calling task chooses
to wait for the segment and a segment large enough is not
available, then the calling task is placed on the region's
segment wait queue and blocked. If the region was created with
the RTEMS.PRIORITY option, then the calling
task is inserted into the
wait queue according to its priority. However, if the region
was created with the RTEMS.FIFO option, then the calling
task is placed at the rear of the wait queue.
The timeout parameter specifies the maximum interval
that a task is willing to wait to obtain a segment. If timeout
is set to RTEMS.NO_TIMEOUT, then the
calling task will wait forever.
The actual length of the allocated segment may be larger than the requested size because a segment size is always a multiple of the region's page size.
The following segment acquisition option constants are defined by RTEMS:
RTEMS.WAIT - task will wait for semaphore (default)
RTEMS.NO_WAIT - task should not wait
A clock tick is required to support the timeout functionality of this directive.
