RTEMS Logo
RTEMS 4.6.0 On-Line Library
Timer Manager TIMER_INITIATE_SERVER - Initiate server for task-based timers
8.4.7: TIMER_INITIATE_SERVER - Initiate server for task-based timers
CALLING SEQUENCE:
procedure Timer_Initiate_Server (
   Stack_Size    : in     RTEMS.Unsigned32;
   Attribute_Set : in     RTEMS.Attribute;
   Result        :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - Timer Server initiated successfully
RTEMS.TOO_MANY - too many tasks created
DESCRIPTION:
This directive initiates the Timer Server task. This task is responsible for executing all timers initiated via the rtems.timer_server_fire_after or rtems.timer_server_fire_when directives.
NOTES:
This directive could cause the calling task to be preempted.
The Timer Server task is created using the rtems.task_create service and must be accounted for when configuring the system.
Even through this directive invokes the rtems.task_create and rtems.task_start directives, it should only fail due to resource allocation problems.
