RTEMS Logo
RTEMS 4.6.0 On-Line Library
Interrupt Manager INTERRUPT_CATCH - Establish an ISR
6.4.1: INTERRUPT_CATCH - Establish an ISR
CALLING SEQUENCE:
procedure Interrupt_Catch (
   New_ISR_handler : in     RTEMS.Address;
   Vector          : in     RTEMS.Vector_Number;
   Old_ISR_Handler :    out RTEMS.Address;
   Result          :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - ISR established successfully
RTEMS.INVALID_NUMBER - illegal vector number
RTEMS.INVALID_ADDRESS - illegal ISR entry point or invalid old_isr_handler
DESCRIPTION:
This directive establishes an interrupt service routine (ISR) for the specified interrupt vector number. The new_isr_handler parameter specifies the entry point of the ISR. The entry point of the previous ISR for the specified vector is returned in old_isr_handler.
To release an interrupt vector, pass the old handler's address obtained when the vector was first capture.
NOTES:
This directive will not cause the calling task to be preempted.
