procedure Task_Variable_Get ( ID : in RTEMS.ID; Task_Variable : out RTEMS.Address; Task_Variable_Value : out RTEMS.Address; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - per task variable added successfully
RTEMS.INVALID_ID - invalid task id
RTEMS.NO_MEMORY - invalid task id
RTEMS.ILLEGAL_ON_REMOTE_OBJECT - not supported on remote tasks
This directive looks up the private value of a task variable for a specified task and stores that value in the location pointed to by the result argument. The specified task is usually not the calling task, which can get its private value by directly accessing the variable.
If you change memory which result points to, remember to declare that
memory as volatile, so that the compiler will optimize it correctly. In this
case both the pointer result and data referenced by result
should be considered volatile.
