The clock facilities of the clock manager operate upon calendar time. These directives utilize the following date and time record for the native time and date format:
type Time_Of_Day is record Year : RTEMS.Unsigned32; -- year, A.D. Month : RTEMS.Unsigned32; -- month, 1 .. 12 Day : RTEMS.Unsigned32; -- day, 1 .. 31 Hour : RTEMS.Unsigned32; -- hour, 0 .. 23 Minute : RTEMS.Unsigned32; -- minute, 0 .. 59 Second : RTEMS.Unsigned32; -- second, 0 .. 59 Ticks : RTEMS.Unsigned32; -- elapsed ticks between seconds end record;
The native date and time format is the only format
supported when setting the system date and time using the
rtems.clock_get
directive. Some applications
expect to operate on a "UNIX-style" date and time data structure. The
rtems.clock_get
directive can optionally return
the current date and time in the
following record:
type Clock_Time_Value is record Seconds : Unsigned32; Microseconds : Unsigned32; end record;
The seconds field in this record is the number of seconds since the RTEMS epoch of January 1, 1988.
