Getting Started with GNAT/RTEMS
Create a build directory for the SIS Debugger
cd tools mkdir build-ppc
Configure the GNU Debugger for the PowerPC Instruction Simulator (PSIM):
cd tools/build-ppc
../gdb-4.17/configure \
--target=powerpc-unknown-eabi \
--program-prefix=powerpc-rtems- \
--enable-sim-powerpc \
--enable-sim-timebase \
--enable-sim-inline \
--enable-sim-hardware \
--enable-targets=all \
--prefix=<INSTALL_POINT_FOR_PPC>
Where <INSTALL_POINT_FOR_PPC> is a unique location where the gdb with PSIM will be created.
From tools/build-ppc execute the following command sequence:
make all install
NOTE: The make utility used should be GNU make.
