OAR
RTEMS 4.5.0 On-Line Library
Application Executable
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
5.4: Application Executable
If the sample application has successfully been build, then the application executable is placed in the following directory:
tools/hello_world_ada/o-optimize/<filename>.exe
How this executable is downloaded to the target board is very dependent on the BOARD_SUPPORT_PACKAGE selected.
