OAR
RTEMS 4.5.0 On-Line Library
Building RTEMS for a Specific Target and BSP
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
4.5: Building RTEMS for a Specific Target and BSP
  • Using the RTEMS configure Script Directly
  • Using the bit_rtems Script
  • This section describes how to configure and build RTEMS so that it is specifically tailored for your BSP and the CPU model it uses. There are two methods to compile and install RTEMS:
    Direct invocation of configure and make provides more control and easier recovery from problems when building.
    This section describes how to build RTEMS.
