OAR
RTEMS 4.5.0 On-Line Library
Unarchive the RTEMS Source
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
4.2: Unarchive the RTEMS Source
Use the following command sequence to unpack the RTEMS source into the tools directory:
cd tools
tar xzf ../archive/rtems-4.5.0.tgz
This creates the directory rtems-4.5.0.
