Getting Started with GNAT/RTEMS
The build scripts are written in "shell". The program /bin/sh
on Solaris 2.x is not robust enough to execute these scripts. If you
are on a Solaris 2.x host, then change the first line of the files
bit_ada
, bit_gdb
, and bit_rtems
to use the
/bin/ksh
shell instead.
