OAR
RTEMS 4.5.0 On-Line Library
Software Architecture
PREV UP NEXT Bookshelf RTEMS/GDB User's Guide
Chapter 2: Software Architecture
RTEMS/GDB host-target debugger is architectured around:
The host debugger communicates with the debug server using Sun RPC over UDP/IP (Ethernet).
When opening a debugging session, the user takes the control over the entire target system. The target system is viewed as a single multi-threaded process.
The debugger can observe the state of the system objects, without stopping the entire system. However, breakpoints and stepping affect (stop) the entire system.
For a given target, only one single system debugging session is possible at a time.
