abort
- Abnormal termination of a program
abs
- Integer absolute value (magnitude)
assert
- Macro for Debugging Diagnostics
atexit
- Request execution of functions at program exit
atof
- String to double or float
atoi
- String to integer
bsearch
- Binary search
calloc
- Allocate space for arrays
div
- Divide two integers
ecvtbuf
- Double or float to string of digits
ecvt
- Double or float to string of digits (malloc result)
__env_lock
- Lock environment list for getenv and setenv
gvcvt
- Format double or float as string
exit
- End program execution
getenv
- Look up environment variable
labs
- Long integer absolute value (magnitude)
ldiv
- Divide two long integers
malloc
- Allocate memory
realloc
- Reallocate memory
free
- Free previously allocated memory
mallinfo
- Get information about allocated memory
__malloc_lock
- Lock memory pool for malloc and free
mbstowcs
- Minimal multibyte string to wide string converter
mblen
- Minimal multibyte length
mbtowc
- Minimal multibyte to wide character converter
qsort
- Sort an array
rand
- Pseudo-random numbers
strtod
strtol
- String to long
strtoul
- String to unsigned long
system
- Execute command string
wcstombs
- Minimal wide string to multibyte string converter
wctomb
- Minimal wide character to multibyte converter
