OAR
RTEMS 4.5.0 On-Line Library
Thread Manager pthread_detach - Detach a Thread
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.19: pthread_detach - Detach a Thread
CALLING SEQUENCE:
#include <pthread.h>
int pthread_detach(
  pthread_t thread
STATUS CODES:
ESRCH
The thread specified is invalid.
EINVAL
The thread specified is not a joinable thread.
DESCRIPTION:
The pthread_detach routine is used to to indicate that storage for thread can be reclaimed when the thread terminates without another thread joinging with it.
NOTES:
If any threads have previously joined with the specified thread, then they will remain joined with that thread. Any subsequent calls to pthread_join on the specified thread will fail.
