OAR
RTEMS 4.5.0 On-Line Library
Thread Manager pthread_attr_setinheritsched - Set Inherit Scheduler Flag
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.11: pthread_attr_setinheritsched - Set Inherit Scheduler Flag
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setinheritsched(
  pthread_attr_t *attr,
  int             inheritsched
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The specified scheduler inheritance argument is invalid.
DESCRIPTION:
The pthread_attr_setinheritsched routine is used to set the inherit scheduler field in the thread attribute object attr to the value specified by inheritsched.
The contentionscope must be either PTHREAD_INHERIT_SCHED to indicate that the thread is to inherit the scheduling policy and parameters fromthe creating thread, or PTHREAD_EXPLICIT_SCHED to indicate that the scheduling policy and parameters for this thread are to be set from the corresponding values in the attributes object. If contentionscope is PTHREAD_INHERIT_SCHED, then the scheduling attributes in the attr structure will be ignored at thread creation time.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_PRIORITY_SCHEDULING to indicate that the family of routines to which this routine belongs is supported.
