OAR
RTEMS 4.5.0 On-Line Library
Thread Manager pthread_attr_setstackaddr - Set Thread Stack Address
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.7: pthread_attr_setstackaddr - Set Thread Stack Address
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setstackaddr(
  pthread_attr_t *attr,
  void           *stackaddr
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
DESCRIPTION:
The pthread_attr_setstackaddr routine is used to set the stackaddr attribute in the attr thread attribute object.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_ATTR_STACKADDR to indicate that this routine is supported.
It is imperative to the proper operation of the system that each thread have sufficient stack space.
