OAR
RTEMS 4.5.0 On-Line Library
Message Passing Manager mq_getattr - Get Message Queue Attributes
PREV UP next Bookshelf RTEMS POSIX API User's Guide
16.4.8: mq_getattr - Get Message Queue Attributes
CALLING SEQUENCE:
#include <mqueue.h>
int mq_getattr(
  mqd_t mqdes,
  struct mq_attr *mqstat
STATUS CODES:
EBADF - The message queue descriptor does not refer to a valid, open message queue.
DESCRIPTION:
The mqdes argument specifies a message queue descriptor. The mq_getattr function is used to get status information and attributes of the message queue associated with the message queue descriptor. The results are returned in the mq_attr structure referenced by the mqstat argument. All of these attributes are set at create time, except the blocking/non-blocking behavior of the message queue which can be dynamically set by using mq_setattr. The attribute mq_curmsg is set to reflect the number of messages on the queue at the time that mq_getattr was called.
Upon successful completion, the mq_getattr function returns zero. Otherwise, the function returns -1 and sets errno to indicate the error.
NOTES:
