OAR
RTEMS 4.5.0 On-Line Library
Message Passing Manager POSIX Interpretation Issues
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
16.2.6: POSIX Interpretation Issues
There is one significant point of interpretation related to the RTEMS implementation of POSIX message queues:
What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking?
The RTEMS POSIX implementation decided to unblock all waiting tasks with an EAGAIN status just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen alternative behaviors.
