OAR
RTEMS 4.5.0 On-Line Library
Timer Manager System Calls
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
15.4: System Calls
  • Timer Manager timer_create - Create a Per-Process Timer
  • Timer Manager timer_delete - Delete a Per-Process Timer
  • Timer Manager timer_settime - Set Next Timer Expiration
  • Timer Manager timer_gettime - Get Time Remaining on Timer
  • Timer Manager timer_getoverrun - Get Timer Overrun Count
  • This section details the timer manager's services. A subsection is dedicated to each of this manager's services and describes the calling sequence, related constants, usage, and status codes.
