OAR
RTEMS 4.5.0 On-Line Library
Clock Manager nanosleep - Delay with High Resolution
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
14.4.5: nanosleep - Delay with High Resolution
CALLING SEQUENCE:
#include <time.h>
int nanosleep(
  const struct timespec *rqtp,
  struct timespec       *rmtp
STATUS CODES:
On error, this routine returns -1 and sets errno to one of the following:
EINTR
The routine was interrupted by a signal.
EAGAIN
The requested sleep period specified negative seconds or nanoseconds.
EINVAL
The requested sleep period specified an invalid number for the nanoseconds field.
DESCRIPTION:
NOTES:
This call is interruptible by a signal.
