OAR
RTEMS 4.5.0 On-Line Library
Condition Variable Manager pthread_cond_signal - Signal a Condition Variable
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
11.4.7: pthread_cond_signal - Signal a Condition Variable
CALLING SEQUENCE:
#include <pthread.h>
int pthread_cond_signal(
  pthread_cond_t *cond
STATUS CODES:
EINVAL
The specified condition variable is not valid.
DESCRIPTION:
NOTES:
This routine should not be invoked from a handler from an asynchronous signal handler or an interrupt service routine.
