OAR
RTEMS 4.5.0 On-Line Library
Mutex Manager pthread_mutexattr_getprotocol - Get the Blocking Protocol
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
10.4.4: pthread_mutexattr_getprotocol - Get the Blocking Protocol
CALLING SEQUENCE:
#include <pthread.h>
int pthread_mutexattr_getprotocol(
  pthread_mutexattr_t *attr,
  int                 *protocol
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The protocol pointer argument is invalid.
DESCRIPTION:
The pthread_mutexattr_getprotocol routine is used to obtain the value of the protocol attribute. This attribute controls the order in which threads waiting on this mutex will receive it.
NOTES:
NONE
