OAR
RTEMS 4.5.0 On-Line Library
Mutex Manager Mutex Attributes
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
10.2.1: Mutex Attributes
Mutex attributes are utilized only at mutex creation time. A mutex attribute structure may be initialized and passed as an argument to the mutex_init routine. Note that the priority ceiling of a mutex may be set at run-time.
blocking protcol
is the XXX
priority ceiling
is the XXX
pshared
is the XXX
