OAR
RTEMS 4.5.0 On-Line Library
Semaphore Manager sem_close - Close a named semaphore
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
9.4.4: sem_close - Close a named semaphore
CALLING SEQUENCE:
int sem_close(
  sem_t *sem_close
STATUS CODES:
EACCES
The semaphore argument is not a valid semaphore descriptor.
ENOSYS
The function sem_close is not supported by this implementation.
DESCRIPTION:
The sem_close() function is used to indicate that the calling process is finished using the named semaphore indicated by sem. The function sem_close deallocates any system resources that were previously allocated by a sem_open system call. If sem_close() completes successfully it returns a 1, otherwise a value of -1 is return and errno is set.
NOTES:
