OAR
RTEMS 4.5.0 On-Line Library
Input and Output Primitives Manager dup2 - Duplicates an open file descriptor
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
5.4.3: dup2 - Duplicates an open file descriptor
CALLING SEQUENCE:
#include <unistd.h>
int dup2(
  int fildes,
  int fildes2
STATUS CODES:
EBADF
Invalid file descriptor.
EINTR
Function was interrupted by a signal.
EMFILE
The process already has the maximum number of file descriptors open and tried to open a new one.
DESCRIPTION:
Dup2 creates a copy of the file descriptor oldfd.
The old and new descriptors may be used interchangeably. They share locks, file position pointers and flags; for example, if the file position is modified by using lseek on one of the descriptors, the position is also changed for the other.
NOTES:
NONE
