OAR
RTEMS 4.5.0 On-Line Library
Files and Directories Manager fpathconf - Gets configuration values for files
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.32: fpathconf - Gets configuration values for files
CALLING SEQUENCE:
#include <unistd.h>
int fpathconf(
  int filedes,
  int name
STATUS CODES:
EINVAL
Invalid argument
EACCES
Permission to write the file is denied
ENAMETOOLONG
Length of a filename string exceeds PATH_MAX and _POSIX_NO_TRUNC is in effect.
ENOENT
A file or directory does not exist
ENOTDIR
A component of the specified path was not a directory whan a directory was expected.
DESCRIPTION:
pathconf() gets a value for the configuration option name for the open file descriptor filedes.
The possible values for name are:
_PC_LINK_MAX
returns the maximum number of links to the file. If filedes or path refer to a directory, then the value applies to the whole directory. The corresponding macro is _POSIX_LINK_MAX.
_PC_MAX_CANON
returns the maximum length of a formatted input line, where filedes or path must refer to a terminal. The corresponding macro is _POSIX_MAX_CANON.
_PC_MAX_INPUT
returns the maximum length of an input line, where filedes or path must refer to a terminal. The corresponding macro is _POSIX_MAX_INPUT.
_PC_NAME_MAX
returns the maximum length of a filename in the directory path or filedes. The process is allowed to create. The corresponding macro is _POSIX_NAME_MAX.
_PC_PATH_MAX
returns the maximum length of a relative pathname when path or filedes is the current working directory. The corresponding macro is _POSIX_PATH_MAX.
_PC_PIPE_BUF
returns the size of the pipe buffer, where filedes must refer to a pipe or FIFO and path must refer to a FIFO. The corresponding macro is _POSIX_PIPE_BUF.
_PC_CHOWN_RESTRICTED
returns nonzero if the chown() call may not be used on this file. If filedes or path refer to a directory, then this applies to all files in that directory. The corresponding macro is _POSIX_CHOWN_RESTRICTED.
NOTES:
NONE
