OAR
RTEMS 4.5.0 On-Line Library
Files and Directories Manager rmdir - Delete a directory
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.18: rmdir - Delete a directory
CALLING SEQUENCE:
#include <unistd.h>
int rmdir(
  const char *pathname
STATUS CODES:
EPERM
The filesystem containing pathname does not support the removal of directories.
EFAULT
pathname points ouside your accessible address space.
EACCES
Write access to the directory containing pathname was not allowed for the process's effective uid, or one of the directories in pathname did not allow search (execute) permission.
EPERM
The directory containing pathname has the stickybit (S_ISVTX) set and the process's effective uid is neither the uid of the file to be delected nor that of the director containing it.
ENAMETOOLONG
pathname was too long.
ENOENT
A dirctory component in pathname does not exist or is a dangling symbolic link.
ENOTDIR
pathname, or a component used as a directory in pathname, is not, in fact, a directory.
ENOTEMPTY
pathname contains entries other than . and .. .
EBUSY
pathname is the current working directory or root directory of some process
EBUSY
pathname is the current directory or root directory of some process.
ENOMEM
Insufficient kernel memory was available
EROGS
pathname refers to a file on a read-only filesystem.
ELOOP
pathname contains a reference to a circular symbolic link
DESCRIPTION:
rmdir deletes a directory, which must be empty
NOTES:
NONE
