OAR
RTEMS 4.5.0 On-Line Library
Files and Directories Manager closedir - Ends directory read operation
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.6: closedir - Ends directory read operation
CALLING SEQUENCE:
#include <sys/types.h>
#include <dirent.h>
int closedir(
  DIR *dirp
STATUS CODES:
EBADF
Invalid file descriptor
DESCRIPTION:
The directory stream associated with dirp is closed. The value in dirp may not be usable after a call to closedir().
NOTES:
NONE
The argument to closedir() must be a pointer returned by opendir(). If it is not, the results are not portable and most likely unpleasant.
The routine is implemented in Cygnus newlib.
