OAR
RTEMS 4.5.0 On-Line Library
Files and Directories Manager rewinddir - Resets the readdir() pointer
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.3: rewinddir - Resets the readdir() pointer
CALLING SEQUENCE:
#include <sys/types.h>
#include <dirent.h>
void rewinddir(
  DIR *dirp
STATUS CODES:
No value is returned.
DESCRIPTION:
The rewinddir() function resets the position associated with the directory stream pointed to by dirp. It also causes the directory stream to refer to the current state of the directory.
NOTES:
NONE
If dirp is not a pointer by opendir(), the results are undefined.
The routine is implemented in Cygnus newlib.
