OAR
RTEMS 4.5.0 On-Line Library
Map Process Addresses to a Memory Object
PREV UP NEXT Bookshelf RTEMS POSIX 1003.1 Compliance Guide
12.2.1: Map Process Addresses to a Memory Object
mmap(), Function, Unimplemented
PROT_READ, Constant,  Unimplemented
PROT_WRITE, Constant,  Unimplemented
PROT_EXEC, Constant,  Unimplemented
PROT_NONE, Constant,  Unimplemented
MAP_SHARED, Constant,  Unimplemented
MAP_PRIVATE, Constant,  Unimplemented
MAP_FIXED, Constant,  Unimplemented
