OAR
RTEMS 4.5.0 On-Line Library
Referenced C Language Routines
PREV UP NEXT Bookshelf RTEMS POSIX 1003.1 Compliance Guide
8.1: Referenced C Language Routines
  • Extensions to Time Functions
  • Extensions to setlocale Function
  • ANSI C Section 4.2 --- Diagnostics
    assert(), Function, Implemented
    ANSI C Section 4.3 --- Character Handling
    isalnum(), Function, Implemented
    isalpha(), Function, Implemented
    iscntrl(), Function, Implemented
    isdigit(), Function, Implemented
    isgraph(), Function, Implemented
    islower(), Function, Implemented
    isprint(), Function, Implemented
    ispunct(), Function, Implemented
    isspace(), Function, Implemented
    isupper(), Function, Implemented
    isxdigit(), Function, Implemented
    tolower(), Function, Implemented
    toupper(), Function, Implemented
    ANSI C Section 4.4 --- Localization
    setlocale(), Function, Implemented
    ANSI C Section 4.5 --- Mathematics
    acos(), Function, Implemented
    asin(), Function, Implemented
    atan(), Function, Implemented
    atan2(), Function, Implemented
    cosh(), Function, Implemented
    sinh(), Function, Implemented
    tanh(), Function, Implemented
    exp(), Function, Implemented
    frexp(), Function, Implemented
    ldexp(), Function, Implemented
    log(), Function, Implemented
    log10(), Function, Implemented
    modf(), Function, Implemented
    pow(), Function, Implemented
    sqrt(), Function, Implemented
    ceil(), Function, Implemented
    fabs(), Function, Implemented
    floor(), Function, Implemented
    fmod(), Function, Implemented
    ANSI C Section 4.6 --- Non-Local Jumps
    setjmp(), Function, Implemented
    longjmp(), Function, Implemented
    ANSI C Section 4.9 --- Input/Output
    FILE, Type, Implemented
    clearerr(), Function, Implemented
    fclose(), Function, Implemented
    feof(), Function, Implemented
    ferror(), Function, Implemented
    fflush(), Function, Implemented
    fgetc(), Function, Implemented
    fgets(), Function, Implemented
    fopen(), Function, Implemented
    fputc(), Function, Implemented
    fputs(), Function, Implemented
    fread(), Function, Implemented
    freopen(), Function, Implemented
    fseek(), Function, Implemented
    ftell(), Function, Implemented
    fwrite(), Function, Implemented
    getchar(), Function, Implemented
    perror(), Function, Implemented
    printf(), Function, Implemented
    fprintf(), Function, Implemented
    sprintf(), Function, Implemented
    putchar(), Function, Implemented
    remove(), Function, Implemented
    rewind(), Function, Implemented
    scanf(), Function, Implemented
    fscanf(), Function, Implemented
    sscanf(), Function, Implemented
    setbuf(), Function, Implemented
    tmpfile(), Function, Implemented
    tmpnam(), Function, Implemented
    ungetc(), Function, Implemented
    NOTE: rename is also included in another section. Rename a File.
    ANSI C Section 4.10 --- General Utilities
    atof(), Function, Implemented
    atoi(), Function, Implemented
    atol(), Function, Implemented
    rand(), Function, Implemented
    srand(), Function, Implemented
    calloc(), Function, Implemented
    free(), Function, Implemented
    malloc(), Function, Implemented
    realloc(), Function, Implemented
    abort(), Function, Implemented
    exit(), Function, Implemented
    bsearch(), Function, Implemented
    qsort(), Function, Implemented
    NOTE: getenv is also included in another section. Environment Access.
    ANSI C Section 4.11 --- String Handling
    strcpy(), Function, Implemented
    strncpy(), Function, Implemented
    strcat(), Function, Implemented
    strncat(), Function, Implemented
    strcmp(), Function, Implemented
    strncmp(), Function, Implemented
    strchr(), Function, Implemented
    strcspn(), Function, Implemented
    strpbrk(), Function, Implemented
    strrchr(), Function, Implemented
    strspn(), Function, Implemented
    strstr(), Function, Implemented
    strtok(), Function, Implemented
    strlen(), Function, Implemented
    ANSI C Section 4.12 --- Date and Time Handling
    asctime(), Function, Implemented
    gmtime(), Function, Implemented
    localtime(), Function, Implemented
    mktime(), Function, Implemented
    strftime(), Function, Implemented
    NOTE: RTEMS has no notion of time zones.
    NOTE: time is also included in another section. Get System Time.
    From Surrounding Text
    EXIT_SUCCESS, Constant, Implemented
    EXIT_FAILURE, Constant, Implemented
