OAR
RTEMS 4.5.0 On-Line Library
C Language Limits
PREV UP NEXT Bookshelf RTEMS POSIX 1003.1 Compliance Guide
2.9: C Language Limits
  • Minimum Values
  • Run-Time Increasable Values
  • Run-Time Invariant Values (Possible Indeterminate)
  • Pathname Variable Values
  • Invariant Values
  • Maximum Values
  • CHAR_BIT, Constant, Implemented
    CHAR_MAX, Constant, Implemented
    CHAR_MIN, Constant, Implemented
    INT_MAX, Constant, Implemented
    INT_MIN, Constant, Implemented
    LONG_MAX, Constant, Implemented
    LONG_MIN, Constant, Implemented
    MB_LEN_MAX, Constant, Implemented
    SCHAR_MAX, Constant, Implemented
    SCHAR_MIN, Constant, Implemented
    SHRT_MAX, Constant, Implemented
    SHRT_MIN, Constant, Implemented
    UCHAR_MAX, Constant, Implemented
    UINT_MAX, Constant, Implemented
    ULONG_MAX, Constant, Implemented
    USHRT_MAX, Constant, Implemented
    NOTE: These are implemented in GCC's limits.h file.
