OAR
RTEMS 4.5.0 On-Line Library
Netboot DEC driver
PREV UP NEXT Bookshelf RTEMS Network Supplement
6.7: Netboot DEC driver
We use Netboot tool to load our development from a server to the target via an ethernet network. Currently, this tool does not support the DEC board. We plan to port the DEC driver for the Netboot tool.
But concerning the port of the DEC driver into Netboot, we are faced with a problem : in RTEMS environment, the DEC driver is interrupt or event driven, in Netboot environment, it must be used in polling mode. It means that we will have to re-write some mechanisms of this driver.
