The configuration structure for FTPD is as follows:
struct rtems_ftpd_configuration
rtems_task_priority priority; /* FTPD task priority */
unsigned long max_hook_filesize; /* Maximum buffersize */
/* for hooks */
int port; /* Well-known port */
struct rtems_ftpd_hook *hooks; /* List of hooks */
The FTPD task priority is specified with priority. Because
hooks are not saved as files, the received data is placed in an
allocated buffer. max_hook_filesize specifies the maximum
size of this buffer. Finally, hooks is a pointer to the
configured hooks structure.
