RTEMS adds two new SOL_SOCKET
level options for setsockopt
and
getsockopt
: SO_SNDWAKEUP
and SO_RCVWAKEUP
. For both, the
option value should point to a sockwakeup structure. The sockwakeup
structure has the following fields:
void (*sw_pfn) (struct socket *, caddr_t); caddr_t sw_arg;
These options are used to set a function to be called when there is
data available from the socket (SO_RCVWAKEUP
) and when there is space
available to accept data written to the socket (SO_SNDWAKEUP
If setsockopt
is called with the SO_RCVWAKEUP
option, and the
sw_pfn
field is not zero, then when there is data
available to be read from
the socket, the function pointed to by the sw_pfn
field will be
called. A pointer to the socket structure will be passed as the first
argument to the function. The sw_arg
field set by the
SO_RCVWAKEUP
call will be passed as the second argument to the function.
If setsockopt
is called with the SO_SNDWAKEUP
function, and the sw_pfn
there is space available to accept data written to the socket,
field
will be called. The arguments passed to the function will be as with
SO_SNDWAKEUP
When the function is called, the network semaphore will be locked. The function must be careful not to call any networking functions. It is OK to call an RTEMS function; for example, it is OK to send an RTEMS event.
The purpose of these functions is to permit a more efficient alternative to the select call when dealing with a large number of sockets.
